81sunnyson Posted June 9, 2015 Report Share Posted June 9, 2015 ok so head gasket is not even six months old, but blew in 90 degrees weather.head plug also blew. heard a loud pop, steam, rattle original gasket was okay six months ago when i pulled head to fix burnt valve. wish i had left it alone now comp tested 120 psi on first three cylinders but 180 on #4, which had the replaced valve n no compression could cylinder pressure be so uneven to fail the gasket? warped head? torqued head bolts wrong? Quote Link to comment
datzenmike Posted June 9, 2015 Report Share Posted June 9, 2015 What's a head plug? The casting plug, AKA frost plug? Is your temperature gauge working? Sounds like you overheated it. could cylinder pressure be so uneven to fail the gasket? no warped head? Might have been warped before. They usually blow again if they were and it wasn't fixed. It may be warped now. torqued head bolts wrong? Possibly, if it was warped as well or over heated. Quote Link to comment
nismo dr Posted June 9, 2015 Report Share Posted June 9, 2015 ok so head gasket is not even six months old, but blew in 90 degrees weather.head plug also blew. heard a loud pop, steam, rattle original gasket was okay six months ago when i pulled head to fix burnt valve. wish i had left it alone now comp tested 120 psi on first three cylinders but 180 on #4, which had the replaced valve n no compression warped head? torqued head bolts wrong? yes Quote Link to comment
81sunnyson Posted June 9, 2015 Author Report Share Posted June 9, 2015 temp gauge always goes no further the line 1/4 away from cold just heard pop, steam, then overheated cylinder head plug missing in road somewheres had water pumps to fail revving 6000 so i only go 4000 was speeding along at 70mph Quote Link to comment
81sunnyson Posted June 9, 2015 Author Report Share Posted June 9, 2015 coolant over flows into catch can so sure radiator clogged or other issue. foamy always since had it. super grey condensation in winter. Quote Link to comment
datzenmike Posted June 9, 2015 Report Share Posted June 9, 2015 Coolant flow into catch can is normal on coolant recovery equipped vehicles, this is what it does. When the engine cools the coolant siphons back and fills the rad. If you mean over flows the catch can this is a sign of a blown head gasket. Quote Link to comment
81sunnyson Posted June 12, 2015 Author Report Share Posted June 12, 2015 piston has a few nicks....or more like material on surface from gasket fused onto it, which has made indentation on combustion chamber Quote Link to comment
