82m Posted December 2, 2014 Report Share Posted December 2, 2014 So Im putting an A15 into my 620 ute, replacing the J15. I know the engine was a runner as my Dad and I rebuilt it for my brothers B310 coupe. I put a race cam in it and did the head gasket, tensioner etc. But now I cant get it to fire. At first it just wound over with nothing. I checked the spark and it was algood. Then checked the fuel and found a blocked line. Now it winds over and backfires out of the carb. Any suggestions? Cheers Quote Link to comment
flatcat19 Posted December 2, 2014 Report Share Posted December 2, 2014 Backfire? Timing is off. Check dizzy. Check chain. Quote Link to comment
Guest Rick-rat Posted December 2, 2014 Report Share Posted December 2, 2014 Are the plug wires right? Our rotors turn counterclockwise in the dist. Do yours go clockwise down under? :confused: 1 Quote Link to comment
82m Posted December 2, 2014 Author Report Share Posted December 2, 2014 I checked all the wires and they are right and also re set the dizzy, didnt help. haha pretty sure its just the toilet that goes the other way.. will have to pull off the chain covers and have another look.. Quote Link to comment
Guest Rick-rat Posted December 2, 2014 Report Share Posted December 2, 2014 Good luck figuring this out, valve lash too tight? Quote Link to comment
wayno Posted December 2, 2014 Report Share Posted December 2, 2014 I do believe that dust devils also turn the opposite way down there also, at least most the time. I don't mean to dwell on this, but you must be sure that the wires go on the dist. counter clockwise. Are the wires dirty and touching anything, is the cap dirty, if it sat a long time, did you check to see if the inside of the cap is wet? Quote Link to comment
ryanthomas1 Posted December 24, 2014 Report Share Posted December 24, 2014 Backfire tells you that the intake valve is open on the power stroke, this means two things , 1. Could be valve float , (check valve lash) 2. Timing could be off, (timing light, check distributor ) Quote Link to comment
82m Posted December 26, 2014 Author Report Share Posted December 26, 2014 Hey guys, cheers for the help. I managed to get it started yesterday, an excellent Christmas present to myself haha. I had the distributor 180 out. feel like an idiot haha but at least now I know that the chains all timed up correctly. But now it starts but wont idle.I can keep it going if I hold the revs up but as soon as I let go it dies almost instantly. Do I have it too advanced? Ive tried turning up the idle screw but that doesn't help much. Cheers and Merry Christmas. Quote Link to comment
