dscottdatsun Posted November 8, 2014 Report Share Posted November 8, 2014 Is 5W30 oil okay to run in a L20B? I know 30 WT is what is normal but its not always what's available. Quote Link to comment
datzenmike Posted November 8, 2014 Report Share Posted November 8, 2014 No! Follow the car maker's recommended oil viscosity. Select an oil based on the lowest temp expected before your next oil change. For Washington state I don't imagine the winter temps to drop much below 15 or 20 F so at least 10W30 (which is good to zero F) I run 15W40 Chevron Dello 400 or 15W40 Shell Rotella T in my L20Bs. This is a 'light diesel' oil but mainly for it's higher ZDDP level. Quote Link to comment
wayno Posted November 9, 2014 Report Share Posted November 9, 2014 I use 20/50 in all my gas engines, and Delo400 in my diesels. I used whatever oil was bought the cheapest in my work truck when it had the L20b, it used so much oil, that I just kept it full of anything I could buy, I used the cheap stuff as I was going threw a gallon a week, or 3 quarts+ a tank on road trips, it really didn't smoke that bad, but it had so much blow-by, that it was hard to keep gaskets from leaking, there was oil on the ground where I parked it, but it was only a few spots, not big puddles, it burnt most the oil. That engine made me think about oil and Datsun engines differently than I had before, the L20b engine is over built, as long as you keep oil and antifreeze in the engine, it will run forever, I had not changed the oil in that engine for the last 3 years, as it had new oil in it every couple weeks, I just changed the oil filter every year weather it needed it or not. :lol: I now have a LZ23, I still use 20/50, but now I have to change the oil, as it doesn't need any top offs anymore, so now I have to actually watch the mileage, what a pain, but I don't have a 100 dollar bill a month for oil anymore either, I just cannot win. :lol: Quote Link to comment
datzenmike Posted November 9, 2014 Report Share Posted November 9, 2014 Can you tell which main bearing is the 140 hp KA24E and which is the 94 hp L20B Quote Link to comment
