EndStar Posted November 2, 2014 Report Share Posted November 2, 2014 I have a 280z and took of my 4bbl and need to figure out a list of parts i need to finish my SU setup. mostly worried about how to set up my fuel delivery. Quote Link to comment
ericsb210 Posted November 2, 2014 Report Share Posted November 2, 2014 Just my motto, don't where jewelry in the engine bay. Includes watches. Sorry, not familiar with SU's. Quote Link to comment
john510 Posted November 2, 2014 Report Share Posted November 2, 2014 You just need a tee off of the fuel line from the fuel pump,one line to each carb or put the tee at the first carb and run to the second.If you're using a stock fuel pump you shouldnt need a fuel pressure regulator. 1 Quote Link to comment
EndStar Posted November 3, 2014 Author Report Share Posted November 3, 2014 You just need a tee off of the fuel line from the fuel pump,one line to each carb or put the tee at the first carb and run to the second.If you're using a stock fuel pump you shouldnt need a fuel pressure regulator. i know its an electric pump, am im only hesitant and putting the T on the first one because it wont equally distribute the fuel, unless it doesnt matter Quote Link to comment
EndStar Posted November 3, 2014 Author Report Share Posted November 3, 2014 Just my motto, don't where jewelry in the engine bay. Includes watches. Sorry, not familiar with SU's. i never do, just forgot to take pics so i took them before i went back to college Quote Link to comment
EndStar Posted November 3, 2014 Author Report Share Posted November 3, 2014 do you think this line would work, or too small? Quote Link to comment
dgi Posted November 3, 2014 Report Share Posted November 3, 2014 Check out the two pictures in my thread about my '75. They show an original fuel line setup which includes a return line. Might help you determine how to proceed. 1 Quote Link to comment
EndStar Posted November 3, 2014 Author Report Share Posted November 3, 2014 Check out the two pictures in my thread about my '75. They show an original fuel line setup which includes a return line. Might help you determine how to proceed. so you have it split to 2 seperate lines then 1 goes to front carb and the other to the rear? Quote Link to comment
dgi Posted November 4, 2014 Report Share Posted November 4, 2014 No, look closer. This is a factory fuel line taken from a '72 240Z (I think, but it could be a '73). Front carb is fed from a tee (hard to see) in the lower metal line. Rear carb is fed from the short curved metal line off the bottom of a little square block at the back end of the line. The block connects the lower line to the upper line also. The entire upper line is a return line. Theoretically this provides the same fuel pressure to both carbs as they both get fuel via a tee in the line as the fuel passes down the line and back through the return. Both carbs vent to fitting on the back of the stock air cleaner. Quote Link to comment
EndStar Posted November 4, 2014 Author Report Share Posted November 4, 2014 No, look closer. This is a factory fuel line taken from a '72 240Z (I think, but it could be a '73). Front carb is fed from a tee (hard to see) in the lower metal line. Rear carb is fed from the short curved metal line off the bottom of a little square block at the back end of the line. The block connects the lower line to the upper line also. The entire upper line is a return line. Theoretically this provides the same fuel pressure to both carbs as they both get fuel via a tee in the line as the fuel passes down the line and back through the return. Both carbs vent to fitting on the back of the stock air cleaner. so the front tees off from one line, and the rear is fed by both lines then. that would work pretty well if i can set it up correctly Quote Link to comment
dgi Posted November 4, 2014 Report Share Posted November 4, 2014 No. Front and rear are fed by the lower line. Any excess fuel flows on through the block, into the upper (return) line, and back to the tank. Quote Link to comment
