jeremyd72 Posted August 6, 2014 Report Share Posted August 6, 2014 I am putting a FS5W63A out of a 78 B210 into my 1980 210 and the speedometer pinion is not the same. The threads for the cable are stripped on the FS5W63A so I need to know of another Datsun that uses the same pinion. Thanks, Jeremy Quote Link to comment
PineClone Posted August 8, 2014 Report Share Posted August 8, 2014 Are you looking for the pinion or the entire body/sleeve that it fits in to? You can order the pinions through Nissan and they're available from other sources as well i think. This webpage has the part numbers. You just need to figure out how many teeth you need. Quote Link to comment
jeremyd72 Posted August 8, 2014 Author Report Share Posted August 8, 2014 I need the sleeve. The threads where the cable screws onto are messed up. Quote Link to comment
jeremyd72 Posted August 9, 2014 Author Report Share Posted August 9, 2014 I thought a photo would help. Quote Link to comment
datzenmike Posted August 9, 2014 Report Share Posted August 9, 2014 That sleeve (only) is used in the Roadster 311 / 521 / 510 / 610 / 710 / A10 / S10 (5 spd.) / early 620 pickup. Someone probably has an old 4 speed laying around with one in it. Quote Link to comment
