NC280z Posted July 16, 2014 Report Share Posted July 16, 2014 Good evening all! So the OEM camshaft I ordered finally arrived, however it's missing the cam sprocket location dowel. I've searched the forum, internet and the FSM and can't locate a part number for a new dowel or even a factory-prescribed method on removing/installing the dowel. The best I've seen is to just get a dowel and tap it into place. I'm just curious to see if any of you have removed/installed dowel pins on L-series camshafts before, and could give me a size or part # so I can start sourcing one now in preparation for installing it this weekend. If I can get this pin and install my cam I should have a running Z by Sunday, and it's been too long since I had it on the road. Any help will be appreciated, as always. Thanks! Quote Link to comment
datzenmike Posted July 16, 2014 Report Share Posted July 16, 2014 L series cam dowel 13032-18000 about a buck from the dealer. Used in all L, Z, VG, J, A, CA, maybe more. Still being used in 2004 or later Quote Link to comment
NC280z Posted July 17, 2014 Author Report Share Posted July 17, 2014 Thank you kindly! I called a local dealer with the part number, and will be getting the dowel this Friday for about $2. This definitely saved another possible weekend from being wasted, thanks again. Quote Link to comment
