Dilligaf Posted July 10, 2014 Report Share Posted July 10, 2014 Just wondering if anyone has used a hilux diff or is there a stronger nissan diff that would suit the 720 also if anyone has photos of there 4link suspension? looking for diff gears between 3.5-3.7 by the way. Quote Link to comment
datzenmike Posted July 10, 2014 Report Share Posted July 10, 2014 The Nissan H-190 is tough enough for almost 300 ft lbs. of torque and comes in 3.345, 3.545, 3.700, 3.889, 4.11, 4.375, 4.625.... Quote Link to comment
Dilligaf Posted July 10, 2014 Author Report Share Posted July 10, 2014 Ahh probably should of said something about power figures. will need something to suit 1300nm of torque Quote Link to comment
heretic Posted July 10, 2014 Report Share Posted July 10, 2014 I seriously doubt a Hilux or any other stock axle is going to handle that kinda torque. ..... will need something to suit 1300nm of torque 1 Quote Link to comment
]2eDeYe Posted July 10, 2014 Report Share Posted July 10, 2014 That's like 1000 ft lbs, seems excessive. You will need a heavily built 9 inch or something of that nature. Twin turbo V8 or something? Keep in mind you will probably need a custom four link designed to resist that amount of torque at the wheels to keep from tearing the axle out of the truck. 1 Quote Link to comment
Dilligaf Posted July 10, 2014 Author Report Share Posted July 10, 2014 Believe it or not but the engine is a Supercharged v6. 1 Quote Link to comment
datzenmike Posted July 10, 2014 Report Share Posted July 10, 2014 Then a Hilux and the stock H-190 aren't even in the running, besides, no LSD. Take a look at the WD22 Pathfinder. H-233 (that's larger than the legendary Ford 9") comes with 4 pinion LSD and 180 ft lbs break away on the early ones, 6 bolt so the 620 rims will fit, (well same bolt pattern) Had optional rear disc brakes and best of all is already 4 link coil spring and with panhard bar and a monster sway bar too. 2 Quote Link to comment
Dilligaf Posted July 11, 2014 Author Report Share Posted July 11, 2014 Awesome cheers mike ill look into them! Quote Link to comment
]2eDeYe Posted July 11, 2014 Report Share Posted July 11, 2014 Believe it or not but the engine is a Supercharged v6. Sounds like a good time :D Quote Link to comment
crimsoneclipse Posted July 11, 2014 Report Share Posted July 11, 2014 Please post pics of finished product. seriously, i gotta see this!!! 1 Quote Link to comment
Dilligaf Posted July 12, 2014 Author Report Share Posted July 12, 2014 Ill be starting a build thread on the 620 side of the forums soon, just trying to do all the research i can. Quote Link to comment
