bucketoval Posted May 25, 2007 Report Share Posted May 25, 2007 which 5 speed trans is a bolt in? i am looking at getting a ka24dc and trans from a 92 240sx. what kind of mod will have to do to make it work in my 72 510 2 door?:confused: Quote Link to comment
Icehouse Posted May 26, 2007 Report Share Posted May 26, 2007 Wow, where to start... 1. reverse the crossmember for the front sump engine. 2. Dave Carrol trans mount. 3. Shorten the DL 4. add a walbro or MSD fuel pump. 5. custom radiator 6. put battery in trunk or run a really small one. 7. tons of little mods.... Quote Link to comment
Z-train Posted May 26, 2007 Report Share Posted May 26, 2007 IH-'splain the Dave Carroll trnas mount please. Quote Link to comment
bucketoval Posted May 26, 2007 Author Report Share Posted May 26, 2007 is there a 5 speed trans that bolts in? :confused:the 1600 will do for now. :D Quote Link to comment
tangent Posted May 26, 2007 Report Share Posted May 26, 2007 5 speed tranny out of a 280zx fit under my 521, should fit a 510 get the 81-83 non turbo 5speed better 5th gear. Then when you do the KA swap, you can use the 280 zx tranny as long as you put a NAP Z tranny belhousing on the 5speed.. At least thats the theory Ive gathered.. Quote Link to comment
71-521 Posted May 26, 2007 Report Share Posted May 26, 2007 IH-'splain the Dave Carroll trnas mount please. does Dave have a site or place he sells them from? I know Carter Boad has them as well... Quote Link to comment
Icehouse Posted May 26, 2007 Report Share Posted May 26, 2007 IH-'splain the Dave Carroll trnas mount please. Its a custom mount made for installing any 5 speed in a 510. You can modify yours to make it work its just easier to use the Dave Carrol one. is there a 5 speed trans that bolts in? :confused:the 1600 will do for now. :D Yes there are 3 that bolt in with the stock driveline length.... 1. Dogleg 79-81 200sx I believe 2. Nissan comp. tranny, good luck finding one 3. 1980 720 4x4 with the L motor also anther tuff one to find. 5 speed tranny out of a 280zx fit under my 521, should fit a 510 get the 81-83 non turbo 5speed better 5th gear. Then when you do the KA swap, you can use the 280 zx tranny as long as you put a NAP Z tranny belhousing on the 5speed.. At least thats the theory Ive gathered.. Yes but the DL will need to be shortened. Its only like 80 bucks. And the Dave Carrol bracket makes it easier. does Dave have a site or place he sells them from? I know Carter Boad has them as well... Yep you have to contact Carter Boad, cool guy though :D Quote Link to comment
