crimsoneclipse Posted June 25, 2014 Report Share Posted June 25, 2014 Engine was running normally for a while now. I was checking the engine while it was running, slammed the hood down harder than I should have and then the engine's idle jumped to 1500 RPM. What the hell did I do? Did I shock a switch in the carb? Note, the vacuum system has been mostly removed as is the EGR valve. Contemplating slamming the hood again to see if it returns to normal. CE Quote Link to comment
datzenmike Posted June 25, 2014 Report Share Posted June 25, 2014 I assumed you stepped on the gas several times to see if this would dislodge it??? Check the throttle cable is loose enough for the throttle plate to close completely to idle. Try adjusting the idle speed screw down Check that the fast idle cam is fully off and choke plate fully open. Quote Link to comment
crimsoneclipse Posted June 25, 2014 Author Report Share Posted June 25, 2014 Re-slamming the hood didn't work.... (worked on a cell phone once... fixed the screen.... go figure) The throttle cable is fine and not binding. I'll adjust the idle again. It just seems so binary. either fast or slow. I'm guessing something broke loose. Quote Link to comment
