JLB 78 620 Posted June 11, 2014 Report Share Posted June 11, 2014 I have a 1978 620 king cab with a auto trains I'm putting a 5 speed out of a 1980 720 king cab both are l20b powered. I have been told the 1984 z24 clutch and flywheel fit and what all do I need to do to make it work? Quote Link to comment
datzenmike Posted June 11, 2014 Report Share Posted June 11, 2014 Nothing, it bolts right on. You will need to use the 240mm clutch and PP and the release bearing collar for any Z24 motor from the 720 Quote Link to comment
JLB 78 620 Posted June 11, 2014 Author Report Share Posted June 11, 2014 Thank you that helps. Got another question may be stuped bit here go's going from a auto do I need any weight on the front of the engine? Quote Link to comment
dr.feltersnatch Posted June 11, 2014 Report Share Posted June 11, 2014 Do you mean the harmonic balancer? Quote Link to comment
