1969 dime Posted June 7, 2014 Report Share Posted June 7, 2014 Hi guys I'm new here so excuse the newb question. I have dual 44mm mikuni's and I need air filters and horns. I have 2 velocity stacks that are 80mm diameter at the widest point and 50mm tall. I would like to get 2 more of the same. My question is, Do filters for Webers fit on Mikuni's? And do the air horns for Webers fit on mikuni's? Thanks for your help. Quote Link to comment
ggzilla Posted June 7, 2014 Report Share Posted June 7, 2014 Sock filters yes Bolt on filters no. The flanges are different. I used Weber DCOE filters on my Mikuni 40s but had to drill fuel bowl vent holes in the flange and gasket. Quote Link to comment
hang_510 Posted June 7, 2014 Report Share Posted June 7, 2014 airhorns are not interchangeable between the two. Quote Link to comment
1969 dime Posted June 7, 2014 Author Report Share Posted June 7, 2014 Awesome. Thanks for the quick response. I tried to post a pic of the air filter I want to use.(not the sock) It's the common rectangular weber style that bolts to the carb. Then has the outside plate that clips on and sandwiches the air filter. I will get those and drill/ modify them. Wolfcreek the best place to get stacks? Quote Link to comment
hang_510 Posted June 7, 2014 Report Share Posted June 7, 2014 Wolfcreek the best place to get stacks? best??? good for sure. Quote Link to comment
