D.D.Anderson Posted May 31, 2014 Report Share Posted May 31, 2014 Im now going to install my new cylinder head soon. The old bolts is marked 13". the Center T bolt was marked 12T". I brought new bolts for A14, but is marked 12". Does that matter? Remember, engine only gone 92000. Quote Link to comment
Guest Rick-rat Posted June 1, 2014 Report Share Posted June 1, 2014 Why can't you use the bolts you took out? 1 Quote Link to comment
spottedog Posted June 1, 2014 Report Share Posted June 1, 2014 Note that the longer bolts are on the right hand side, and ONE OF THEM IS A SMALLER DIAMETER THAN THE OTHERS This bolt goes in the middle hole on the right hand side and is marked "12T" on it's head. Quote Link to comment
D.D.Anderson Posted June 1, 2014 Author Report Share Posted June 1, 2014 Why can't you use the bolts you took out? Well my mate is autorized mechanic and tells me NOOOT to do it. So now i really don't know, i thought it would be ok but. I know 12T is going on middle, but the other bolts is marked 12's so i guess they are same as 13's only lower torque required? Quote Link to comment
ggzilla Posted June 1, 2014 Report Share Posted June 1, 2014 The 12 bolts are weaker than the 13 bolt, so use the 13 bolts. Unlike some modern engines with TTY bolts, Datsun head bolts can be reused. Quote Link to comment
Cpl620 Posted June 1, 2014 Report Share Posted June 1, 2014 if its a small engine with a mild compression i wouldn't put too much thought into reusing head bolts again. but if they are being torqued a 3rd or 4th time, grab new ones. is it ideal to reuse them, no. do you run a slight risk of the bolts failing, yes. but like i said. a normal L series is not going to make enough power to really put stress on the bolt to failure. just torque to highest factory spec and call it a day. out of all of the stock engine ive done head work on, and reused the bolts, ive never had a problem pertaining to the head bolts. 1 Quote Link to comment
datzenmike Posted June 1, 2014 Report Share Posted June 1, 2014 The center bolt #11057-H5700 is common to all A13/14/15 heads and allows oil up from the block and so is narrower. The other A13/14/15 head bolts #11056-H2301 are the same and also used on the Z20 and Z22 engines in the 200sx, A10 and the 720 truck. Quote Link to comment
