flatcat19 Posted May 23, 2014 Report Share Posted May 23, 2014 Soooooooooooo... I need a radiator for the 210 A to L swap. The A radiator has both the inlet and outlet on the opposite sides as an L. (I wish I had a picture of the opening) There are holes at 17 1/4" that I can put some J-clips in...But there will be a huge gap on one side. There is another set of holes at about 20" apart but then there are pillars that prevent me from going bigger. I CAN go bigger if I put some spacers there-but would rather be as flush as possible. Radiators I've tried: A10-too tall(3-4") and too wide(1/2"-3/4" on each side.) 521- 1" wide on each side---with an odd exception. 620-Damn near perfect. BUT...aren't there 2 or 3 different 620 radiators? The exception with the 521 is that the Champion radiator in Keven's truck is not as wide as the OE 521 rad. we had in hand. Other radiator mounting width's? Something I'm not thinking of? I'd like to go with the Champion-just not positive of fitment yet. 1 Quote Link to comment
ggzilla Posted May 23, 2014 Report Share Posted May 23, 2014 240SX radiator? $70 new aluminum It fits, takes up the whole front. Quote Link to comment
datzenmike Posted May 24, 2014 Report Share Posted May 24, 2014 May not fit between the headlights. Quote Link to comment
flatcat19 Posted May 24, 2014 Author Report Share Posted May 24, 2014 Anything wider the 20" mounting width will be bumping into things. I want one flush against the core and want to use a stock L shroud. Quote Link to comment
