67_1600 Posted May 16, 2014 Report Share Posted May 16, 2014 I'm replacing my control arm bushings and am in the middle of reassembly and cannot find the torque setting for the self-locking nut that attaches the control arm to the crossmember in my Haynes manual. I'm sure it's probably there, but they don't always use the same terminology when describing things one place and then giving torque settings in another. Does anyone have the setting by chance? Thanks! Quote Link to comment
ggzilla Posted May 16, 2014 Report Share Posted May 16, 2014 Datsun calls it the "transverse link bush". Since the pin uses an M14 nut, torque it appropriate to the nut. Most Datsun suspension bolts are medium carbon steel. http://www.dansmc.com/torque_chart.htm Quote Link to comment
Sealik Posted May 16, 2014 Report Share Posted May 16, 2014 http://www.nicoclub.com/FSM/510/510%20Service%20Manual%20Chassis%20and%20Body/510%20Service%20Manual%20%20FA.PDF Transverse link to suspension cross member fixing nut 2,2toL9,5 kg-m (88.2 to 97.6 ft-Ib) Drop the car on the ground before torquing to specs Quote Link to comment
67_1600 Posted May 16, 2014 Author Report Share Posted May 16, 2014 Sweet, thanks guys. Quote Link to comment
