bonvo Posted June 23, 2014 Report Share Posted June 23, 2014 uuum timing isnt right if you set it at 20 degrees advance at idle its supposed to be at 12 degrees before tdc not 20 Quote Link to comment
Curt Posted June 23, 2014 Author Report Share Posted June 23, 2014 Ok, I was wording it wrong... Then it is at 20deg before tdc. The O on the tab is tdc, correct. So it is between the 20 and the 10. so it is damn near at 12deg. Quote Link to comment
Curt Posted June 23, 2014 Author Report Share Posted June 23, 2014 Ok, So lets now assume the timing is correct. lol. It was at 15deg before tdc. For some reason my brain likes to think advanced when the pulley notch mark is before the 0 mark on the plate... Now it is at 12 deg. Does this shit look correct? Two of the 4 wires running to the old carb in pic two. Will these make a difference? do they need to be routed somewhere or something? Quote Link to comment
