WallRocket Posted March 29, 2014 Report Share Posted March 29, 2014 I can not....for the life of me...figure out how to put back together my 1979 datsun steering box. I separated the steering shaft out of the box. Can't seem to line up the gears, or have no idea how to put it back in... I have never worked with gear boxes. Quote Link to comment
flatcat19 Posted March 29, 2014 Report Share Posted March 29, 2014 Then why did you even take it apart? 1 Quote Link to comment
WallRocket Posted March 29, 2014 Author Report Share Posted March 29, 2014 Its a sr20det build. I am a very experienced car mechanic. Just never missed with gear boxes, besides adjusting them. I figured it cant be to hard.... Quote Link to comment
WallRocket Posted March 29, 2014 Author Report Share Posted March 29, 2014 It has to be removed to install the turbo, then put back in. Quote Link to comment
flatcat19 Posted March 29, 2014 Report Share Posted March 29, 2014 Bottom mount would still rub on steering column. You would have needed a top mount. To get it together it just kind of fits. No real tips to give. GL. Quote Link to comment
WallRocket Posted March 29, 2014 Author Report Share Posted March 29, 2014 I had it all installed. Go look at my build status. No need for top mount. Anyone know the process? Do you line up with one side, and turn the steering wheel into the box? Quote Link to comment
TENDRIL Posted March 30, 2014 Report Share Posted March 30, 2014 edited =useless info sorry Quote Link to comment
jvb5577 Posted March 30, 2014 Report Share Posted March 30, 2014 I'll have to take a look at my manual, its for a '73 but I am sure they are the same. I was going to swap steering boxes a while ago and took a look and remember it saying.. "Do not remove" unless necessary. So I think what I am going to find is it is going to be a B***H Quote Link to comment
WallRocket Posted March 30, 2014 Author Report Share Posted March 30, 2014 Awesome lol Quote Link to comment
WallRocket Posted March 30, 2014 Author Report Share Posted March 30, 2014 Yay me! Hope my tubo never goes out..... Haha Quote Link to comment
WallRocket Posted March 30, 2014 Author Report Share Posted March 30, 2014 Replacing turbo < Steering gear box Quote Link to comment
WallRocket Posted March 30, 2014 Author Report Share Posted March 30, 2014 Here is what i am working with. Quote Link to comment
jvb5577 Posted March 30, 2014 Report Share Posted March 30, 2014 Hope that helps. 1 Quote Link to comment
WallRocket Posted March 30, 2014 Author Report Share Posted March 30, 2014 You bet. Can't thank you enough. BTW Anyone else runs into this problem. Just remove the pitman arm, and slide the shaft out from the top. Then install the steering shaft, and then put back in the shaft. Quote Link to comment
datzenmike Posted March 30, 2014 Report Share Posted March 30, 2014 I took mine apart years ago. When I screwed the worm in it popped the plug out of the front and all the juice poured out. (groan) I did get it together again and may have removed the sector shaft to do this. It was a long time ago. Quote Link to comment
