Jason Wright Posted March 14, 2014 Report Share Posted March 14, 2014 wasup fellow 720 fans! i have a !985 nissan 720 ext cab and i want to install a aftermarket sub enclosure. has anyone tried this yet? did you use a factory or custom box? the bigger the better. i was thinking of 2 solo baric L7 myself. :thumbup: Quote Link to comment
ggzilla Posted March 14, 2014 Report Share Posted March 14, 2014 Use the factory sub enclosure. What? Quote Link to comment
Jason Wright Posted March 14, 2014 Author Report Share Posted March 14, 2014 i meant an enclosure that was already built. like the ones from kicker or other audio companies, Quote Link to comment
ggzilla Posted March 14, 2014 Report Share Posted March 14, 2014 Yes its been done. See http://community.ratsun.net/topic/39870-subwoofers Quote Link to comment
datzenmike Posted March 14, 2014 Report Share Posted March 14, 2014 You can make an enclosure cheaper (definitely better quality) and larger than pre made ones. Be sure your seat is where you want it and make some measurements from the passenger side. Allow for the seat belt retractors. The sums for my 620 kc were sloping at the front to follow the back of the seat, vertical against the rear wall, wide enough side to side to fit between the floor hump and the seat belt retractors, about 5" front to back on top and about 13" front to back on the bottoms to fit a 10" sub. I set all four corners off the floor by 2 " by attaching blocks of wood. This allows the speaker to fire downward and can't be seen or damaged. You can even stack groceries on top. Covered everything but the bottom with grill cloth. I think 1.5 cu. ft. volume each, but I forget The 720 has even more room back there so get at er. Sheet of 3/4" plywood, grill cloth, screws and glue... maybe $60 Quote Link to comment
