filthy forever Posted March 13, 2014 Report Share Posted March 13, 2014 Im swapping in a KA into my 720 and I was at the junkyard today and I found a single cam KA in a stanza and was wondering if the TPS and MAF would work? I would imagine it would because they the same engines. any advice is greatly appreciated. Quote Link to comment
ggzilla Posted March 13, 2014 Report Share Posted March 13, 2014 Not the same engine. The fwd versions are quite different. Quote Link to comment
datzenmike Posted March 13, 2014 Report Share Posted March 13, 2014 I assume the KA that you are swapping into the 720 is from a S13 (240sx)?????? If so... yes the throttle position sensor 22620-35F00 (manual transmission) and 22620-45V00 (automatic transmission) MAF 22680-40F00 are identical to those on the '90 and up Stanza. (who would have thunk it?). Quote Link to comment
filthy forever Posted March 13, 2014 Author Report Share Posted March 13, 2014 ^^^ thank you again datsunmike your knowledge is astounding. im swapping in a hardbody KA but with the s13 intake manifold so what I gathered from you these sensors should work. Quote Link to comment
filthy forever Posted March 13, 2014 Author Report Share Posted March 13, 2014 another question ive been pondering is, would it be possible to swap out the fuel tank from a harbody (with an internal pump) into a 720? that way when I use the CAN AM the relay will power the pump. Quote Link to comment
datzenmike Posted March 13, 2014 Report Share Posted March 13, 2014 Can't say it is a direct fit but if KC to KC or long wheelbase to long wheelbase it probably would be easy enough.to make it fit. ^^^ thank you again datsunmike your knowledge is astounding. im swapping in a hardbody KA but with the s13 intake manifold so what I gathered from you these sensors should work. In this case it was knowing where to look for the answer. The D-21 uses a throttle body that combines the MAF and TPS Quote Link to comment
