Cooper78b210 Posted February 15, 2014 Report Share Posted February 15, 2014 Ok I've got a 78 b210 automatic, no a/c. My fan pulley is wiggling and I know it is attached to the water pump, so this mean's I need a new water pump or fan or what? I need advice fast so I can get my baby back on the road. Quote Link to comment
MicroMachinery Posted February 15, 2014 Report Share Posted February 15, 2014 Check the bolts first. If the bolts are tight, then yes, the water pump bearing is worn out and the pump needs to be replaced. 1 Quote Link to comment
datzenmike Posted February 15, 2014 Report Share Posted February 15, 2014 It's probably has a clutch fan but matters not which part is loose. The clutch cannot be removed from the pump so the complete water pump needs to be replaced anyway.. Quote Link to comment
Cooper78b210 Posted February 15, 2014 Author Report Share Posted February 15, 2014 Ok so replace the water pump. That's what i thought. Thank you gentleman Quote Link to comment
ggzilla Posted February 16, 2014 Report Share Posted February 16, 2014 B210 clutch fan is removable as are most clutch fans B210 non-AC has simple fan Quote Link to comment
datzenmike Posted February 16, 2014 Report Share Posted February 16, 2014 Maybe on the B-210 but not on most other Datsuns. Never seen one although I have heard the early Z car did. Quote Link to comment
