Rocha410 Posted February 12, 2014 Report Share Posted February 12, 2014 whats up everyone new to the forum looking for some help putting my stock carb back together. I just recently put a weber on it but didn't like it ran fine but the pedal felt alot dif and i just want to keep my motor stock besides my header. I just put 5.29 gears in my yota +axle's so its quick enough. I took the weber off and put my old carb back on I just have no idea how everything hooks up as far as all the original vacuum lines and what not. I hooked up the main incoming fuel line started it up and it was blowing fuel out of another line right next to the main fuel line located right around the float bowl not sure if that's normal. I put all new inside the carb everything the rebuild kit comes with. I'm at the point where i just need to hook up all the vac lines and important lines that i need. If anyone would be willing to post some pics of their stock engine bays and carb i would much appreciate it or just give me an idea of how to hook everything up correctly again thanks. Michael. heres a couple pics from my last trail run. Quote Link to comment
datzenmike Posted February 12, 2014 Report Share Posted February 12, 2014 Where the fuel is coming out is the bowel vent. It goes to the charcoal canister. There reason for the gas is the float chamber is over filled... maybe the float is set wrong or there's dirt in the needle valve preventing it closing properly. Look on the glass bulls eye on the font and you'll see it over full.. Quote Link to comment
Rocha410 Posted February 12, 2014 Author Report Share Posted February 12, 2014 alright that makes sense i have to adjust the float, bend that tab so it's higher up closing the needle valve completely when the bowl's full right Quote Link to comment
datzenmike Posted February 12, 2014 Report Share Posted February 12, 2014 Check the needle isn't stuck but yeah, that about right. Quote Link to comment
Rocha410 Posted February 12, 2014 Author Report Share Posted February 12, 2014 alright right on as far as the vac lines since i dont have to smog for couple years witch ones can i eliminate and witch ones should i run? Quote Link to comment
ggzilla Posted February 12, 2014 Report Share Posted February 12, 2014 Be careful not to lose the float pivot spacer, a very common problem. Run the vacuum advance, crankcase ventilatio, and fuel tank venting hoses. Quote Link to comment
mattthom1986 Posted February 15, 2014 Report Share Posted February 15, 2014 I don't have any helpful advice, I just want to see more pictures of these trucks. Please. Quote Link to comment
