1973 620 need a 5 speed transmission
i have a 1973 datsun 620 built 08/73 has the short shaft 4 speed transmission. i have a 75 with long shaft tranny. im looking to put a 5 speed in the 73. i have a crossmember for the long shaft but i dont have a driveline. im looking at buying a 5 speed out of a 1983 280zx . will the driveline out of the 280zx work with my 620? or will i have to shorten my driveline? and will the tranny work out of the 1983 zx ? was told the tranny would work . but i would like to get some more feedback from a few Datsun shade tree Geniuses. Thanks in advance
  • Replies 6
I just installed a 5spd from an 81 zx in my 73 620.  Only mod that I had to do was have the front drive shaft portion shortened.  After lowering the truck 3 inches, I found that just having a single driveshaft made more sense.  That's how she is now.
I would love to get rid of the dead carrier bearing in my truck.  How is the gear ratio with the 71B trans?  And I'm assuming you did this in a short bed truck?
donnie:  Why not just use the 5spd you have, and have the driveshaft from your '73, built to fit?  Seems like a lot less trouble.  You can take the driveshaft to a driveshaft shop, and have it lengthen or shortened.
Yes, short bed 73 truck.
Gear ratio is great.  I got this truck to drive into town, 20 miles each way.  No issues at all on the freeway doing around 80 the whole time.
If it's a non turbo 280zx instal the transmission with the front half of the driveshaft and the tranny mount and cross member from the '75. Good to go.
