EatLag Posted January 8, 2014 Report Share Posted January 8, 2014 Well, i put on my cleaned carby two days ago, it ran PERFECT, and tonight just after i replaced the rubber fuel lines at the fuel pump, it sputters like horse shit when im driving in about 3rd, now i was thinking that the engine was just cold as the temp gauge hasnt moved and the thermostat is stuck open but what are your thaughts guys? Quote Link to comment
datzenmike Posted January 8, 2014 Report Share Posted January 8, 2014 You need to drive 20 min or so for full warm up. Hot air from the heater would be a check. Did you replace the fuel filter? Disturbing the fuel lines may have loosened some dirt and sent it into the carb? Quote Link to comment
EatLag Posted January 8, 2014 Author Report Share Posted January 8, 2014 Fuck, if some dirt has been sent into the carb do I have to pull the whole thing off again to clean it? Quote Link to comment
EatLag Posted January 8, 2014 Author Report Share Posted January 8, 2014 Could it be caused by an incorrect set mixture screw?, also I think I tucked up the order of the vacuum hoses going to the carby Quote Link to comment
datzenmike Posted January 9, 2014 Report Share Posted January 9, 2014 It's called the idle mixture screw. It only adjusts the idle nothing else. Well, i put on my cleaned carby two days ago, it ran PERFECT, and tonight just after i replaced the rubber fuel lines at the fuel pump, it sputters like horse shit when im driving in about 3rd, now i was thinking that the engine was just cold as the temp gauge hasnt moved and the thermostat is stuck open but what are your thaughts guys? Is the engine cold? or not. Quote Link to comment
EatLag Posted January 9, 2014 Author Report Share Posted January 9, 2014 Never mind i think i fixed it, dick head me didnt realise one of the dizzy leads was off Quote Link to comment
datzenmike Posted January 9, 2014 Report Share Posted January 9, 2014 Interesting thing about the dual plugs. It needs way less advance... like 3-5 degrees vs. the L series with 12. If one coil is not firing the Z series will act extremely retarded. Quote Link to comment
