Enrique20 Posted January 5, 2014 Report Share Posted January 5, 2014 the l20b that i currently have in the 510 that seems to loose power/strength it sputers and dosent want to rev up when underload at certain rpms. its timed and had new timing chain kit new ngk plugs new dizzy new carb but i cant find out what its causing this, also when i rev up on neutral and it kinda wants to die and i have to let off the gas and pump the trottle so i wont die on me. is there any thing this could be? ive rebuilt the engine cleaned evrything and i still can seem to get it run properly. Quote Link to comment
datzenmike Posted January 5, 2014 Report Share Posted January 5, 2014 Primary jet partly clogged? Quote Link to comment
Enrique20 Posted January 5, 2014 Author Report Share Posted January 5, 2014 you think? cus the damn carb is brand new. ohh also the second jet or the one that is operated by a vacuum gets the engine to rev up very nicely. i can post a video n you tube showing what is does. Quote Link to comment
flatcat19 Posted January 5, 2014 Report Share Posted January 5, 2014 Brand new? Or rebuilt? Even new parts go bad. What carb? An OE? Weber? Do you have a vacuum? Quote Link to comment
Enrique20 Posted January 5, 2014 Author Report Share Posted January 5, 2014 true, its a new one from international carburetors, yes i do. Quote Link to comment
flatcat19 Posted January 5, 2014 Report Share Posted January 5, 2014 I meant vacuum leak. So a reman'd OE carb? I'd say source a NEW Weber and be happy. Quote Link to comment
Enrique20 Posted January 5, 2014 Author Report Share Posted January 5, 2014 yeah i want to get a new webber but im kinda broke lol Quote Link to comment
datzenmike Posted January 5, 2014 Report Share Posted January 5, 2014 Even a new carb can be fed dirt from the fuel pump. Idle would likely be unaffected. If the primary jet was plugged I doubt you would get it to rev high enough to get the secondary to come in. With lots of pumping to use the accelerator pump to supply the gas needed. Having the choke on would help. Partly blocked would just have really crappy throttle response, motor would rev slowly if at all and then with luck the secondary would kick in and off it would go. Quote Link to comment
dr.feltersnatch Posted January 5, 2014 Report Share Posted January 5, 2014 was the carb ever tuned after it was installed? is the choke hooked up properly and does it fully turn off? Quote Link to comment
