Gregtastic Posted December 27, 2013 Report Share Posted December 27, 2013 So my I decided to upgrade my gauges in my car and the first one I decided to buy was a water temp gauge.. so my question is what size fitting do I need to buy to fit the prob into my thermostat housing ? the one that came with the gauge was a NPT 3/8 and I am assuming that the threads on the car are not NPT. the car is a 1972 510 L18. thanks in advance! Quote Link to comment
Gregtastic Posted December 27, 2013 Author Report Share Posted December 27, 2013 anyone? Quote Link to comment
DanielC Posted December 27, 2013 Report Share Posted December 27, 2013 I do not think it is a normal pipe fitting anyway. It might not even a British thread standard. The stock L-18 temp fitting has a sensor, with a shoulder on it, and a nut that goes over the sensor, that threads into the thermostat housing bottom, and seals that way. There might be a possibility the stock Datsun temp sender could work with an aftermarket gauge. The temp sender is just a temperature sensitive resistor, that has a high resistance when cold, and a lower resistance when hot. A stock Datsun temp sender should be around 40 ohms, at 80 Degrees C, or 176 Degrees F. Quote Link to comment
Gregtastic Posted December 28, 2013 Author Report Share Posted December 28, 2013 yea but i bought a mechanical gauge so thats not gunna work lol thank you though Quote Link to comment
Ranman72 Posted December 28, 2013 Report Share Posted December 28, 2013 pull the threaded collor out that holds the sensor in and take that to osh or lowes or napa etc and match the threads Quote Link to comment
