Quick release stock steering wheel?
reese
  • Replies 6
Im sure its possible, but youd have to make some sort of custom adapter. Quick releases bolt to the steering wheel via 5 or 6 bolts whereas the stock wheel slides over the column teeth and is secured via a center nut. In theory I bet you could custom drill the backside of the wheel to match the QR pattern and bolt it together by removing the horn pad. I dont know how tough that material would be to allow you to securely fasten it to the column though.
I wouldnt chance it. Im sure something could be done though.
