Suntzuzuki Posted September 25, 2013 Report Share Posted September 25, 2013 Hi Guys, The bolt that holds the alternator bracket that screws directly into the block has fallen off. Any idea what I need to replace it with? 1971 521 Also, I have a pinhole leak on the bottom plate of the radiator. Can you guys recommend a good radiator shop in Seattle or nearby? Thanks! Nick Quote Link to comment
DanielC Posted September 25, 2013 Report Share Posted September 25, 2013 Different L-engines had different bolt sizes holding the alternator bracket on the block. What engine is in your truck? Quote Link to comment
Suntzuzuki Posted September 25, 2013 Author Report Share Posted September 25, 2013 Sorry, L16 Thanks, Nick Quote Link to comment
DanielC Posted September 25, 2013 Report Share Posted September 25, 2013 One option is to drill out the alternator bracket bolt holes in the block witha 5/16 drill, and then use a 3/8-16 tap to cut new threads. Do not drill the hole deeper. You might have to tap the hole twice, first with a normal tapered tap, then a bottoming tap. Go to a hardware store, and get two Allen socket cap screws, and the Allen wrench to fit, 3/8-16 by about 1 inch long, with hardened SAE 3/8 flat washers. Use those to attach the lower alternator bracket to the block. Later L-engines used M10-1.5 bolts to hold the lower alternator bracket. The L-16 used M8-1.25 bolts to hold the bracket. If you are a purist, you could get metric taps, and use the M10-1.5 bolts I know a good radiator shop down here, In Oregon City, Superior Radiator, but you are in Seattle. Quote Link to comment
Suntzuzuki Posted September 26, 2013 Author Report Share Posted September 26, 2013 Thanks so much! Quote Link to comment
