HRH Posted September 22, 2013 Report Share Posted September 22, 2013 Balljoint trucks only, can someone go measure their 620 and let me know what the track width is? Preferably with the wheels off and wheel hub edge (where the wheel would bolt on) but other than that, in the center of the tread? Rough approximation is fine, I just need a comparison. I have the FSM for 1978 and that is a dimension it doesn't list. Can't find it on google or bing. Lots of threads about it though. Quote Link to comment
datzenmike Posted September 22, 2013 Report Share Posted September 22, 2013 Up to Feb '73 wheel tread Front... 1,250mm 49.2" Rear.... 1,280mm 50.4" From Mar '73 to Aug '74 wheel tread Front... 1,260mm 49.6" Rear.... 1,290mm 50.8" From Sept '74 to July '75 wheel tread Front... 1,260mm 49.6" Rear.... 1,290mm 50.8" From Aug '75 to Jan '76 wheel tread Front... 1,305mm 51.4" Rear.... 1,290mm 50.8" From Feb '76 to July '77 wheel tread Front... 1,250mm 49.2" Rear.... 1,290mm 50.8" From Aug '77 wheel tread Front... 1,305mm 51.4 Rear.... 1,290mm 50.8 Quote Link to comment
HRH Posted September 22, 2013 Author Report Share Posted September 22, 2013 So that is track width by actual hub face, or by center of tire? And once again, you are awesome Mike! :D Quote Link to comment
datzenmike Posted September 22, 2013 Report Share Posted September 22, 2013 Center of tire to center of tire. Sorry that all the factory gives. Quote Link to comment
HRH Posted September 22, 2013 Author Report Share Posted September 22, 2013 Well, back then with the skinny tires they had and the narrow rims, I'll bet that's exactly track width. Thanks Mike! Interestingly enough a hardbody is 54.9" in the front and 54.5 in the rear. Quote Link to comment
