jhk722 Posted September 6, 2013 Report Share Posted September 6, 2013 Hey guys, Looking to lower my 620 a littler more. I have three inch blocks in the rear and from what I read I can remove a leaf spring to drop her a little more. But I would rather have a direct response before I start in on her, Same for the front, I would rather know exact. pretty sure I can figure it out with the forums I have read already. I read about picking up some pinto front shocks to avoid bottoming out. Any info would be awesome. Thanks! Quote Link to comment
flatcat19 Posted September 6, 2013 Report Share Posted September 6, 2013 Rule 43. Many ways you can go lower. 720 4x4 leafs. One of your leafs. Bigger blocks. As for the front, reclock the bars. That's about it. The shocks are to keep suspension travel. In the general sub section is a "Read This First" FAQ thread. Lots of the stuff you're looking for-like clocking the bars. Quote Link to comment
]2eDeYe Posted September 6, 2013 Report Share Posted September 6, 2013 The pinto shocks aren't really that much of an improvement over the stock ones. I think they maybe have 1/4" more travel. If you are going as low as the end of the shock travel, you will want to address the shock towers. I lengthened mine. Don't forget to get the truck aligned after you get it at the height you like. Quote Link to comment
