Acuna989 Posted September 1, 2013 Report Share Posted September 1, 2013 Long story short, my clutch recently went out. After replacing it I was still having issues. Realized the last owner used a 280 clutch sleeve . Now I'm looking for the correct part. I purchased a sleeve from Nissan and I'm not sure if its the right one. Part number is 30501-n1604. Will this work with a 200mm clutch and flywheel? Quote Link to comment
datzenmike Posted September 1, 2013 Report Share Posted September 1, 2013 Can't locate that number but the correct one for the L16 510 stock clutch is 30501-N1601. The small number difference may simply be the supplier. Quote Link to comment
Acuna989 Posted September 1, 2013 Author Report Share Posted September 1, 2013 Makes sense thats its from a diffent supplier. Looks like the 30501-n1604 is the only sleeve offerd by Nissan now Quote Link to comment
LenRobertson Posted September 1, 2013 Report Share Posted September 1, 2013 Here is a chart with dimensions of the N1601sleeve: http://datsun510.com/photopost/showphoto.php?photo=6981&title=200mm-clutch-t-2fo-bearing-sleeve-specs&cat=3129 You can see if your N1604 sleeve is the same. Len Quote Link to comment
Acuna989 Posted September 2, 2013 Author Report Share Posted September 2, 2013 Here is a chart with dimensions of the N1601sleeve: http://datsun510.com/photopost/showphoto.php?photo=6981&title=200mm-clutch-t-2fo-bearing-sleeve-specs&cat=3129 You can see if your N1604 sleeve is the same. Len Nice! All the dimensions match up to 30501-N1601. Time to put her back together Quote Link to comment
