Batsun Posted August 24, 2013 Report Share Posted August 24, 2013 I have 1974 datsun 620 need help with removing the dash trim around the radio.Thanks batsun Quote Link to comment
datzenmike Posted August 25, 2013 Report Share Posted August 25, 2013 The heater control knobs have a screw on the under side. Pull the he wiper knob all the way out and tightly grip low down on the stem with needle nose pliers. Push the knob in and turn to loosen and lift off. Quote Link to comment
Batsun Posted August 25, 2013 Author Report Share Posted August 25, 2013 There 3 screws above the gauges and those are out, it feels like something still holding it. Quote Link to comment
datzenmike Posted August 25, 2013 Report Share Posted August 25, 2013 SPEEDOMETER CABLE Quote Link to comment
cruznude Posted August 25, 2013 Report Share Posted August 25, 2013 Yes back behind the speedo there is a bracket which is bolted to the bezel. Its hard to find but its there right above steering column. The bezel is kinda snapped in. Use a butter knife or something to slightly pry off bezel. On mine I had to lift up on dash as I went to be able to get out. If you decide to jusdt rip out and want to replace, I have one in 9.9 condition that is a spare. I'd let it go for 100.00 and thats with shipping. Quote Link to comment
