Justin Posted August 10, 2008 Report Share Posted August 10, 2008 So, after bar-hopping the 620 with two other dudes in the cab, I needed to pull (and re-bend:(:mad:) my torsion bar supports, since I started to get "curious" as to how safe it was driving on bottomed-out shocks (and disconnected suspension). :D I thought I'd see how long I could get away with just loosening the bolts- And it turns out it wasn't that long. So it's all re-indexed up and outta the way, but my truck is sitting like 3-4 (5-6) inches higher than before. It looks silly with the tiny wheels I've got! I think now I've over-tightened the torsion-bar bolts, but I plan on mounting pinto shocks and if the bolts pop-out again I think I'll be done for...? But perhaps the only reason they "popped" the 1st time is cause they were hanging too low...? Anyways, I guess my question is after the bars are re-indexed, how worried should a guy be about the bolts breaking loose again...??:mellow: Thanks! Quote Link to comment
]2eDeYe Posted August 10, 2008 Report Share Posted August 10, 2008 If your draggin them, they will pop out. You'll have to re-adjust to get your ride height back. Make sure they are protected by the frame and you'll be fine. Quote Link to comment
Justin Posted August 11, 2008 Author Report Share Posted August 11, 2008 Cool, thanks J2edeye! Quote Link to comment
