Upper and lower link screw bushing torque spec
Zendar
FSM says to torque the upper link screw bushing to 35-55 kg-m (253-398 ft-lb) and lower link screw bushing to 20-30 kg-m (145-217 ft-lb).
Are these specs correct? I tried to torque one of the upper link screw bushings and the threads on the link just gave out...  :mad:
  • Replies 6
hahaha holy shit that is a lot of torque!
just checked my 73 fsm and it says the same. i cant help but feel its a typo.
when did the 620s convert to ball joint? is 77 ball joint? are you referencing a 77 fsm?
720 fsm tq  specs are considerably lower:
upper link:
80-108 ft lb to frame, 12-16 ft lb to upper ball link
lower link
80-108 ft lb to frame, 28-38 ft lb to lower ball joint
