j_boy_619 Posted July 21, 2013 Report Share Posted July 21, 2013 Ok so I have a few questions: 1. My car is idling weird. After the 5 speed swap, my car has been idling (most of the time) at 2,000 RPM. But sometimes it idles at 1,000-1,500 RPM. I can't figure out what's up. I think it might be the choke which leads to my next question. 2. I swapped out the old externally regulated alternator with a new internal one. It's been running fine expect I don't know how to re-wire the voltage regulator. I looked on the forums and found out how to wire the 4 wires, but mine has 6. Anyone know which should be connected to which? 3. I was looking at the carbuetor (trying to figure out the idle) and then I noticed 2 things: - #1 is there supposed to be a bolt or something here? - #2 where does this hose go to? Quote Link to comment
datzenmike Posted July 21, 2013 Report Share Posted July 21, 2013 Join Yellow to White and White/Red stripe to White/Black stripe. Be sure to use solder and heat shrink tubing or lots of electrical tape. I cut the old regulator plug and join the wires on it, when t can simply be plugged into the harness. If your car is like mine, the electric choke relay will now be wired permanently ON. The fix is to disconnect the relay completely. To power the electric choke, go to the carb and join the choke heater wire (usually BLUE) to the idle cut solenoid wire (usually RED). This will give you choke heater when the ignition is on or in the run position. This needs to be plugged with a small bolt or screw. It's the vacuum line that used to go to the auto transmission. It tells the transmission the amount of load on the motor. Heavy throttle = low vacuum. Quote Link to comment
j_boy_619 Posted July 21, 2013 Author Report Share Posted July 21, 2013 for the wiring, what about the other 2 wires? Quote Link to comment
datzenmike Posted July 21, 2013 Report Share Posted July 21, 2013 I used a straightened hair pin to release the barb holding the male connector in the plastic plug and removed them. Neat and tidy and no chance of touching something it shouldn't. Quote Link to comment
j_boy_619 Posted July 21, 2013 Author Report Share Posted July 21, 2013 What? I meant what do i do with the black and black with white line wires? Connect em to each other? Quote Link to comment
datzenmike Posted July 21, 2013 Report Share Posted July 21, 2013 Remove and throw away. I guess I wasn't clear. The picture was to show the little barb that holds them in the plastic connector. For the other two pair you can leave them in place and solder together but you can't get the heat shrink tubing on. Quote Link to comment
j_boy_619 Posted July 22, 2013 Author Report Share Posted July 22, 2013 Alright, update. Thanks to Dat, everything seems to be working fine. The idle I had to do some adjust on my own, but I almost got it down. Thanks! Quote Link to comment
