Master-O-Turbonics Posted July 16, 2013 Report Share Posted July 16, 2013 Here will be a localized place to keep SD22/SD25 information. Basics. The engine had some very advanced technology considering the time it was produced 100mm stroke 3 main bearing crankshaft, 83mm bore deck height of 268mm semi-floating pistons (.0001" interference fit on piston(not a typo), .001-.0018 clearance on the connecting rod to wrist pin) massive 26mm wrist pins piston squirters at bottom of bores integral oil cooler on the side of the block. Here are some images taken from my 1981 720 pickup diesel service manual If you have any requested info, let me know and I will try to get pictures out of my service manual. Basic fluid capacities Recommended fuel and lubricants service data and specs Quote Link to comment
Master-O-Turbonics Posted July 16, 2013 Author Report Share Posted July 16, 2013 Inline pump governor diagram throttle vacuum characteristics altitude compensator(my engine never had one) Quote Link to comment
wayno Posted July 16, 2013 Report Share Posted July 16, 2013 All my SD25s have 5 main bearings. Quote Link to comment
