dave71 Posted May 26, 2013 Report Share Posted May 26, 2013 got a full set of 14'' crome rims but what size ties should i get so it won't throw off my speedo Quote Link to comment
dave71 Posted May 26, 2013 Author Report Share Posted May 26, 2013 ok i meant tires not ties :rolleyes: Quote Link to comment
datzenmike Posted May 26, 2013 Report Share Posted May 26, 2013 I assume this is for your 521? They came stock with 14" rims so just throw stock tires on them. 521 had 6.00 x 14 tires this is equivalent to today's 175/70R14 and that makes them 6.89" wide and 23.65" tall. Have to assume the rim is 6.5 or so. If your replacement rims are wider and you want to avoid 'stretched' tires then... 175/70 R 14s are same height but 6.89" wide 185/65 R 14s are same height but 7.28" wide 190/65 R 14s are same height but 7.48" wide 200/60 R 14s are the same height but 7.87" wide 205/60 R 14s are the same height but 8.07" wide 220/55 R 14s are the same height but 8.66" wide. 225/55 R 14s are the same height but 8.86" wide. 240/50 R 14s are the same height but 9.45" wide. All of the above are within .2" of the same height as the stock tire and the speedo will be unaffected. Quote Link to comment
dave71 Posted May 27, 2013 Author Report Share Posted May 27, 2013 thanks for the list... i saw some 14'' rubber at wally world for 65 bucks a pop but didn't wanna end up w/them to short or to tall Quote Link to comment
slemers Posted May 27, 2013 Report Share Posted May 27, 2013 Online Wheel & Tyre Fitment calculator. Offset, Tyre stretch and Rolling Radius calculator Quote Link to comment
