fuda Posted May 25, 2013 Report Share Posted May 25, 2013 hey everyone i kind of screwed up i was replacing the carrier bearing on my 73 620 after i got it disasembled i got pulled away and side tracked for a bit. when i came back i couldn't remember for the life of me which way the bearing goes back on. i know stupid any way any help would be great. also woulkd like to ask what causes that rubber to blow out so quick i just replaced it about 2 years ago, again any help would be great. thank you Quote Link to comment
Guest_kamakazi620 Posted May 26, 2013 Report Share Posted May 26, 2013 hey everyone i kind of screwed up i was replacing the carrier bearing on my 73 620 after i got it disasembled i got pulled away and side tracked for a bit. when i came back i couldn't remember for the life of me which way the bearing goes back on. i know stupid any way any help would be great. also woulkd like to ask what causes that rubber to blow out so quick i just replaced it about 2 years ago, again any help would be great. thank youis your truck lowered at all??? If so you need to put spacers under it to raise it so the d/l agle is somewhat correct.... Quote Link to comment
datzenmike Posted May 26, 2013 Report Share Posted May 26, 2013 That's what needs replacing not the bearing. Quote Link to comment
Guest_kamakazi620 Posted May 26, 2013 Report Share Posted May 26, 2013 That's what needs replacing not the bearing.yet its bonded to bearing.........sorry Mike Powned......... Quote Link to comment
datzenmike Posted May 26, 2013 Report Share Posted May 26, 2013 Cut a 1 1/2" strip of 1/4" rubber (I had some conveyor belt) and wrap around the bearing and secure with large hose clamp. Clamp it in place with the hoop that normally holds it. I did mine this way and it worked so well I left it.... forever. Should be able to fix this for under $5. The only time I have ever heard of the bearing going bad was recently when metalmonkey47 said his was. Quote Link to comment
Guest_kamakazi620 Posted May 26, 2013 Report Share Posted May 26, 2013 Cut a 1 1/2" strip of 1/4" rubber (I had some conveyor belt) and wrap around the bearing and secure with large hose clamp. Clamp it in place with the hoop that normally holds it. I did mine this way and it worked so well I left it.... forever. Should be able to fix this for under $5. The only time I have ever heard of the bearing going bad was recently when metalmonkey47 said his was.I did this fix the truck vibrated so bad it crack my downpipe on my new exhaust.... Quote Link to comment
datzenmike Posted May 26, 2013 Report Share Posted May 26, 2013 I did this fix the truck vibrated so bad it crack my downpipe on my new exhaust.... Get away. New pipe... cracked???? You're on crack. Quote Link to comment
Guest_kamakazi620 Posted May 26, 2013 Report Share Posted May 26, 2013 Get away. New pipe... cracked???? You're on crack.har har Not the thread to joke in..........true story bro... Quote Link to comment
fuda Posted May 26, 2013 Author Report Share Posted May 26, 2013 Hey no my truck is not lowered. I found a thread with picks that answered which way to put bearing on so that's good. But still no truck is not lowered can use new suspension though... Also have another question about fuel consumption I replaced my carb with the webber carb and changed out to a electric fuel pump, and now I am only getting about 15mpg is tht because of the webber carb? I thought my mpg should be around mid to high 20's on this rig... Any recommendations on how to get better mpg. Quote Link to comment
fuda Posted May 26, 2013 Author Report Share Posted May 26, 2013 Oh and ya the bearing its self was fine the rubber blew out didn't feel like Jerry rigging it seeing how the part was still warrantied... Quote Link to comment
datzenmike Posted May 26, 2013 Report Share Posted May 26, 2013 Was this a new in the box weber? Otherwise you may have bought someone else's problem. You should be getting well up into the 20s even with a weber. What pressure is the fuel pump? 2 1/2 to 3 PSI is lots. Quote Link to comment
fuda Posted May 26, 2013 Author Report Share Posted May 26, 2013 its a new webber that i ordered from webber. i had a carb mechanic put it in as well as the fuel pump not sure what the pressure is, its a facet posi-flow efp3 looked it up and says its 1.5-4 psi. but not sure how correct that is Quote Link to comment
Guest_kamakazi620 Posted May 26, 2013 Report Share Posted May 26, 2013 What motor do you have?? I have an L16 with weber carb a87 peanut head and the worst mileage I've gotten was 22.5 I changed the 3 year old plugs and its back to 25mpg. Quote Link to comment
fuda Posted May 26, 2013 Author Report Share Posted May 26, 2013 stock L16 3 speed auto. plugs are new Quote Link to comment
