btdub Posted April 22, 2013 Report Share Posted April 22, 2013 Please help fellow dimers. I am hearing a grinding/squealing noise in what sounds like my rear passenger wheel area. I only hear it when I take off from a stop, at low speeds occasionally, sometimes at highways speeds while cruising, and it seems to get worse when I make a hard left turn. This has led me to think that the wheel bearing might be going out but from reading I'm not sure if it could be the rear differential. My 510 has the 280zx disc conversion all around and the rear diff is a Subaru LSD connected to and s13 trans. (If it sounds like a diff problem). Any ideas what it could be? I tried to get to the rear bearing today but the lug was too big so I couldn't take it off. I'll probably be getting the right size and trying again tomorrow. When I took the axle arm off the rotor, brake, and hub didn't have any play or resistance when I spun it. No squeaking or grinding either. Even when I was spinning the hub when it was connected to the axle there was no sign of grinding or squeaking. I'm stumped as to what it could be. Any help would be greatly appreciated. Quote Link to comment
btdub Posted April 22, 2013 Author Report Share Posted April 22, 2013 One more thing, the noise gets worse after prolonged driving. So if I drive the highway for a while and come to a stop. When I take off it gets significantly worse. Quote Link to comment
MicroMachinery Posted April 22, 2013 Report Share Posted April 22, 2013 Could be a wheel bearing. Check the u-joints on the axle shaft, as well. Quote Link to comment
datzenmike Posted April 22, 2013 Report Share Posted April 22, 2013 I would carefully inspect all 5 U joints back there. The mounts for the cross member and the diff mounting bolts/mustache bar (you did say subi) so one was bolted in and may have come loose. Quote Link to comment
btdub Posted April 22, 2013 Author Report Share Posted April 22, 2013 Pardon my noob in this area but how would one determine if the U joints are bad? I saw them while I was under there but I don't know exactly what I'm looking for. Thanks for the quick replies! Quote Link to comment
btdub Posted April 22, 2013 Author Report Share Posted April 22, 2013 Did some searching and found mikes write up on u-joints. Thanks for all the help guys. I think I'm headed in the right direction. Seems like a simple fix so I'm gonna head down to the parts store pick up some replacements and go from there. Quote Link to comment
btdub Posted April 22, 2013 Author Report Share Posted April 22, 2013 Does anyone know if there's another u-joint from a different vehicle that might be more durable. The store only has one option for the 510. I'm running sr power and if it's available if rather go with safe than sorry Quote Link to comment
banzai510(hainz) Posted April 22, 2013 Report Share Posted April 22, 2013 Spicer used to make U joints for 510s made in USA and were about 40$ apc back then. have you tried Rockauto.com. look for a US brand. those are usually the repaked Spicer units. Quote Link to comment
TENDRIL Posted April 22, 2013 Report Share Posted April 22, 2013 the reason you weren't able to hear any squeak or grind is because your not able to apply huge amounts weight or force on the areas, so did you pin-point the problem? is it the u-joints, maybe the joints were dry, but at this point if you have been on the joints dry it might be time to replace them anyhow it still sounds like a wheel bearing to me, make sure to inspect both still, since you will be taking that area apart, Quote Link to comment
btdub Posted April 23, 2013 Author Report Share Posted April 23, 2013 I got down under to take a good look at the u joints today. There was no play in them at all but there was grease around the joint as if it may have leaked out. I couldn't get the entire axle off because I didn't have time so I was only able to unbolt half of the axle connected to the wheel hub. Spinning the wheel unattached yielded no sound. But as was mentioned there was no load so I guess it's a shot in the dark. I'm going to see if I can get into the joints tomorrow and grease them up see if it's just the dry joints. If that doesn't go well I'll replace the joints entirely. Any tips on taking off the axle from the diff. It was hard to get in there with the u joint rolling around. The reason i dont want to replace the joints first is cuz the ones on the car are spicers, anddd i didnt want to take it off and not be able to put it back on haha. If its not the joints and it does end up being the wheel bearing. I was reading about the process and I don't know if I have the proper means to do the job right. Some were talking about torquing the nut right and using a tool to get the bearing out. Any enlightenment would be great. Thanks dimers! Quote Link to comment
jessicarobin Posted January 27, 2014 Report Share Posted January 27, 2014 Bad wheel bearing. You definitely can get grinding noises, and sometimes clunking noises... Quote Link to comment
