mas84_720 Posted April 22, 2013 Report Share Posted April 22, 2013 I have noticed on several pictures about lowering a 720, to put lowering blocks on the leaf springs. These pictures show the leaf springs under the axle... mine are above the axle, is this a normal difference between 4x4 and 2wd or were mine flipped to raise it? Mine is a 84 KC 4x4. Quote Link to comment
datzenmike Posted April 22, 2013 Report Share Posted April 22, 2013 Yes the 4x4s have the springs mounted on top of the axle to gain easy road clearance. The springs are also flatter than the 2wd ones, so the gain is at least partly cancelled, and the springs are much stiffer. Quote Link to comment
Bagged620bulletside Posted April 22, 2013 Report Share Posted April 22, 2013 Yes the 4x4s have the springs mounted on top of the axle to gain easy road clearance. The springs are also flatter than the 2wd ones, so the gain is at least partly cancelled, and the springs are much stiffer. Just learned something new, I'm gonna need to find some 4wd leafs for my 2wd. Quote Link to comment
mas84_720 Posted April 23, 2013 Author Report Share Posted April 23, 2013 So could I swap my 4x4 leafs for 2wd leafs and gain a bit more? Im assuming ride would be a bit more comfortable being softer leafs, but are they rated for the same weight? Quote Link to comment
