620 front bumper
Hey guys. Just curious as to how you detach the front chrome
Bumper of a 620. I had a quick look last night on the way to bed but wasn't entirely sure. Can anyone help me out? Is it unscrewed from the inside? Is there any tricks or tips?
  • Replies 5
Yeah they were pretty bad. Thanks man. Ill have a look
Easiest to unbolt the brackets from the frame rails on both sides of the radiators. Then you have 4 bolts on the back side of the bumper. Probably rusty so good luck.
And id assume you'd have to go in from beneath the bumper?
Guest Rick-rat
Under the hood on each side of the radiator  on top of the frame rails there are 4 bolts that hold the bumper brackets, pull it out bumper and brackets together, there could be 2 bolts on the fenders also at the end of the bumper
make sure to quench the bolts with penetration  oil before trying. You might have to back them out a little ways and tighten again then try back them out a little further, back and forth until they come out. Take your time. GL
  • 5 weeks later...
