akumazedex Posted February 16, 2013 Report Share Posted February 16, 2013 Hey everyone, I just switched over to HEI ignition on my 260z, question is, where do I hook up my tach to? I have an aftermarket tach that just needs a signal. On my tach instructions it says if I have gm/HEI ignition I need to hook it up to a tach signal? Otherwise just hook it up to the negative side of the coil. Can I just leave it hooked up to the negative side? Or do I need one of those signal converters? Thanks in advance! :P Quote Link to comment
metalmonkey47 Posted February 16, 2013 Report Share Posted February 16, 2013 You should be good running out of the coil -. I know some newer tachs won't work off of old Datto ignitions because they don't produce a square wave signal and require a signal converter. Dunno about what you have. Quote Link to comment
akumazedex Posted February 16, 2013 Author Report Share Posted February 16, 2013 Cool ill try it out Quote Link to comment
Ooph! Posted February 17, 2013 Report Share Posted February 17, 2013 If it is a stock type HEI there should be "TACH" marked on top of the area where the connections are made. It's been awhile but I believe it's the connection on the end sideways compared to the others. I used the original Chevy two pin connector for the distributor and used a spade lug for the tach on my early model Chevy. Quote Link to comment
akumazedex Posted February 17, 2013 Author Report Share Posted February 17, 2013 This is my HEI set up It gets powered up from the ignition switch and gets signal from the stock 260 dizzy. I can't find anyone that documented the complete wiring for this (tach). Everything works as it should but I can't figure out how to hook up the tach. Quote Link to comment
Ooph! Posted February 17, 2013 Report Share Posted February 17, 2013 Ah I understand what you guy's are doing now, yes the coil (-) would be the place to connect the tach. Quote Link to comment
akumazedex Posted February 17, 2013 Author Report Share Posted February 17, 2013 Thing is, coil + would spark really bad every time j try to connect it, I read somewhere I need a resistor to bring down the voltage to the tach. Quote Link to comment
Ooph! Posted February 18, 2013 Report Share Posted February 18, 2013 try coil Minus Quote Link to comment
re037 Posted February 18, 2013 Report Share Posted February 18, 2013 connect tach (stock blue wire) to coil - . mine had color faded to green so it was confusing for me. also remove the stock transistor from pass side foot area if you havent done so Quote Link to comment
akumazedex Posted February 22, 2013 Author Report Share Posted February 22, 2013 My 260 gets rpm signal directly from the dizzy. :/ Black and green wires from dizzy go straight to tach Quote Link to comment
akumazedex Posted March 13, 2013 Author Report Share Posted March 13, 2013 So still no luck on the tach, even got another one just in case I fried mine. Even ran a resistor to the tach wire with no luck. Ideas? Quote Link to comment
