Engine Trouble
mini&therat
So I have a 1983 720 KC, 2.4, 4X4 with engine troubles. It sounds like valve clatter but those have been checked, fixed and are fine. The cam is good to go. Using a scope, it sounds like the #3 piston is the culprit. The clatter can't be heard at idle but is loud under increasing load. Compression is low but not horrible (110-120ish).
Does anyone know what this could be?
I was thinking of either trying to fix it or replacing it.
If I have to replace, does anyone have an engine in the Puget Sound area for sale or know of a shop that does rebuilds?
I will try to post pics of it soon.
I'm also looking for a stock, front brush guard and stock seats.
Thanks,
Alain
  • Replies 4
Well hard to say.
Check timing... about 3-5 degrees BTDC.
Confirm that both intake and exhaust side coils are firing.
Pull all plugs and compare to the #3 cylinder.
Won't cost anything.
110-120 lbs is horrible. Do a wet compression test to double-check it.
I'm with Mike, the Z24 8-plug heads can make noise if the plug is firing wrong.
So it doesn't look like it's the timing. I'm going to drive it until I find a good replacement or a reasonable rebuild shop.
Any suggestions on a good rebuild shop in the Everett area? I can do a lot of the R&R myself just not the internal rebuild stuff.
Also looking for the following:
--- a pair of black/gray stock seats ---
--- Black/gray door panels ---
--- Stock 4x4 gas tank ---
Thank you all
Bad pics of truck
