JP521 Posted January 18, 2013 Report Share Posted January 18, 2013 Hi everyone! You may notice that the earlier models of the 521 and all the ones that were sold outside USA, also all the 520 family. Come without the hazard switch, the flasher unit, the plugs and the wires related. I wanted to know after make any connection if someone have one of these 521 and tried to put all this missing parts to make work the four turn signal, following the original wiring diagram? or there is a easier way to make this posible? :confused: Thanks!!! Quote Link to comment
DanielC Posted January 18, 2013 Report Share Posted January 18, 2013 I can give you this. And this The power for the turn signals goes through the four way flasher switch, when the switch is off. Turning on the four way flashers disconnects that power. One side of the four way flasher is always hot. Turning on the four way flasher applies that power to both right and left turn signal wires. If the turn signal in is one position or another, right or left, the power does not go anywhere, because the turn signal flashers is no longer connected to anything. Quote Link to comment
