86 720 Posted January 13, 2013 Report Share Posted January 13, 2013 Bought my 200SX sans L20B... PO did not provide the engine mounting perches, hard to contact mechanic has them. Does anyone know if the 510 mounting perches are a direct fit, or do I need to source 200SX perches? Quote Link to comment
ggzilla Posted January 13, 2013 Report Share Posted January 13, 2013 Do you mean the engine mount brackets, the ones that bolt to the engine? Perches make me think of the part welded to the crossmember. Quote Link to comment
86 720 Posted January 13, 2013 Author Report Share Posted January 13, 2013 Do you mean the engine mount brackets, the ones that bolt to the engine? Perches make me think of the part welded to the crossmember. Yes, engine mount brackets. Title changed. Quote Link to comment
Npdavies. Posted January 13, 2013 Report Share Posted January 13, 2013 The 200sx engine mounts can be bought from Rockauto for $6-8 a piece.Don't know about the compatibility between 510/l20b/200sx. Quote Link to comment
datzenmike Posted January 13, 2013 Report Share Posted January 13, 2013 Both S10 200sx side engine brackets are the same as those on the 610/710 The rubber insulator mounts are the same as used on the 610 and L & R are the same part Quote Link to comment
86 720 Posted January 13, 2013 Author Report Share Posted January 13, 2013 Both S10 200sx side engine brackets are the same as those on the 610/710 The rubber insulator mounts are the same as used on the 610 and L & R are the same part I think I was right the first time I posted this... Not the engine mounts. But what the engine mounts bolts to that in turn are bolted to the L20B. Are 200SX perches the same as the 510s? Quote Link to comment
ggzilla Posted January 13, 2013 Report Share Posted January 13, 2013 Never heard them called "perches" before. Those are BRACKETS. They are not the same as 510, but close. They are the same as 610/710. Quote Link to comment
