banzai510(hainz) Posted January 4, 2013 Report Share Posted January 4, 2013 far ass I know the coil is never grounded unless told to by a set of points or the module and if grounded its on the trigger side of the - side coil.(this what turns ir ON/OFF) so read this: so in Datzenmikes photo with the blu wire(goes to -coil) from the remote box. find this wire and should go to the - side coil. "GT 118 12V Oil filled coil Use with external resistor."???????????? key word is use with EXTERNAL reisitor. Since I dont see a resisitor this coil might be cooked already inside youll need to buy a 78 or 79 coil from a 78 620 EI iignition and should be OK to run that voltage. I dont know how this was running before unless you didnt say you fucked with it. Quote Link to comment
Nismo1970 Posted January 4, 2013 Author Report Share Posted January 4, 2013 Ok might give that a shot, shouldn't be that much. and ya i didn't mess with the coil at all. It ran before, but sometimes it wouldn't start right off the bat. it would take a few cranks. and now it'll crank but it sounds like theres no spark to it, and after a few cranks the battary gets low. Quote Link to comment
ggzilla Posted January 4, 2013 Report Share Posted January 4, 2013 That STILL sounds like a wiring problem Now you need to test the wiring. * Turn KEY ON, ENGINE OFF. Measure voltage at coil, be sure there is 12V between battery ground and the coil + terminal * Crank the engine. Is there 12V *while* it is cranking? If not, that is a very common problem causing these symptoms. Quote Link to comment
banzai510(hainz) Posted January 4, 2013 Report Share Posted January 4, 2013 Only thing I can think of is that lower wire in the photo broke off and it up under the hood edgae wher it should be hooked back up to.<br /><br />cause if yoiu look at the loose wire I bet its the -side coil. Quote Link to comment
Nismo1970 Posted January 4, 2013 Author Report Share Posted January 4, 2013 That STILL sounds like a wiring problem Now you need to test the wiring. * Turn KEY ON, ENGINE OFF. Measure voltage at coil, be sure there is 12V between battery ground and the coil + terminal * Crank the engine. Is there 12V *while* it is cranking? If not, that is a common problem causing these symptoms. Ok so i changed out the coil, and it does run 12v when its key on engine off, but when i crank it it drops to 8v or so. Quote Link to comment
ggzilla Posted January 4, 2013 Report Share Posted January 4, 2013 That's the problem. It must be full battery voltage during cranking (something less than 12V, but more than 8V). So check your BAT voltage during cranking. There are two wires in the original harness that come from the ignition switch. If you only have one connected then you won't get the full voltage during cranking. Quote Link to comment
banzai510(hainz) Posted January 4, 2013 Report Share Posted January 4, 2013 MOFO you even ck on that loose wire yet!!!!!!!!!!!!???????????????? thats why there is a tab for a wire hook it up. Quote Link to comment
Nismo1970 Posted January 4, 2013 Author Report Share Posted January 4, 2013 No i dunno qat that wire is, it wasnt connected when it was running good. But ill 2double check it Quote Link to comment
Nismo1970 Posted January 4, 2013 Author Report Share Posted January 4, 2013 And ya the voltage during crank drops to 8v Quote Link to comment
ggzilla Posted January 4, 2013 Report Share Posted January 4, 2013 Now I would test if the engine starts right up with a jump start. 8V sounds like the battery might be worn out. Quote Link to comment
Nismo1970 Posted January 5, 2013 Author Report Share Posted January 5, 2013 Ya no luck with a jump start either Quote Link to comment
ssnapz Posted January 5, 2013 Report Share Posted January 5, 2013 i agree with banzai, if your neg wire aint hooked up it wont run. go through mikes diagram and hook all your wires up that way, if it dont start then, look for your problem. from your pics your wiring is the problem. everything 12v takes 2 wires, neg and pos, if missing one it wont work. fix your neg wire before you do anything else or youll be pissing in the wind. Quote Link to comment
Nismo1970 Posted January 5, 2013 Author Report Share Posted January 5, 2013 Ok ill hook that guy up wats another 3yard buxs. I already spent 75 lol i really appreciate everyones help on this Quote Link to comment
Nismo1970 Posted January 5, 2013 Author Report Share Posted January 5, 2013 Ok so I hooked up the wire. So now when i turn the key to turn it on, it sounds kinda sluggish, it sounds like the battary is dead but it still shows 12v when i test it. any ideas? Quote Link to comment
ggzilla Posted January 5, 2013 Report Share Posted January 5, 2013 Test it. 1. Take the wire back off. Does it spin faster now? It should. 2. Put the wire back on. It will spin slower if it is firing. * Jump start it, does it sping fast now? * Clean (scrape) the battery cable ends and battery terminals down to bare shiny metal. Quote Link to comment
banzai510(hainz) Posted January 6, 2013 Report Share Posted January 6, 2013 if GGzilla think its a low batt voltage ,you could try to find the HOT START wire just in case the RUN wire(ON) isnt reaaly giving the most voltage in the START posititon. like what he said: There are two wires in the original harness that come from the ignition switch. If you only have one connected then you won't get the full voltage during cranking. There are two wires in the original harness that come from the ignition switch. If you only have one connected then you won't get the full voltage during cranking. untill you have it wired up like in Datzenmikes #14 post its not going to run. to me to trouble shoot this is have the batt fully charged take the wire goin in the center of the distributor capplace near ground and start no sprark then thats the issue. the dist is not telling the coil to fire. get your 700$ back in the mean time. thisis EZ to fix get somebody local to fix it for you Quote Link to comment
Nismo1970 Posted January 10, 2013 Author Report Share Posted January 10, 2013 Sounds good, ill try this later today. Thank you for the info. Ill put out an ad for someone near by that can help, hopefully there is someone near me. Ill go back to this jackass mechanic, n see if he'll give me my cash back. Quote Link to comment
banzai510(hainz) Posted January 10, 2013 Report Share Posted January 10, 2013 You could use Datzen mike photo of the whole set up on hoe to hook it up and give to this mechanic and say it dont run . If there is not wire on the other side of the coil this isnt going to run right. PERIOD!!!!!!!! Be honest this should be fixed already its a simple hook up that even you can do if you read out instruction carefully. and the phoot tha Mike provided Quote Link to comment
ggzilla Posted January 10, 2013 Report Share Posted January 10, 2013 I dont THINK its low battery.but suggested he TEST it. Do the easy, quick, tests first. Spend no money until after testing. Quote Link to comment
Nismo1970 Posted January 11, 2013 Author Report Share Posted January 11, 2013 You could use Datzen mike photo of the whole set up on hoe to hook it up and give to this mechanic and say it dont run . If there is not wire on the other side of the coil this isnt going to run right. PERIOD!!!!!!!! Be honest this should be fixed already its a simple hook up that even you can do if you read out instruction carefully. and the phoot tha Mike provided I just woke up, (i work nights) ill get out there right now and check the wiring and hook it up. thanks for the advice. Quote Link to comment
Nismo1970 Posted January 11, 2013 Author Report Share Posted January 11, 2013 I dont THINK its low battery.but suggested he TEST it. Do the easy, quick, tests first. Spend no money until after testing. I'll take it to the nearest store and have it tested, not sure if i'm using the volt reader right :blush: Quote Link to comment
Nismo1970 Posted January 11, 2013 Author Report Share Posted January 11, 2013 Ok. So just got the results. And ggzilla you were right, battery is no good. Step one finished lol. Time to turn in my warrenty lol. Quote Link to comment
banzai510(hainz) Posted January 13, 2013 Report Share Posted January 13, 2013 http://www.rockauto.com/catalog/moreinfo.php?pk=479415&cc=1274554 this is Moron proff matching. coil and matching Ballast for points ,Pertronix, Hot spark, Unilite point conversions 25$ Quote Link to comment
Nismo1970 Posted January 14, 2013 Author Report Share Posted January 14, 2013 http://www.rockauto.com/catalog/moreinfo.php?pk=479415&cc=1274554 this is Moron proff matching. coil and matching Ballast for points ,Pertronix, Hot spark, Unilite point conversions 25$ Is this for an electronic dizzy? Quote Link to comment
Guest Rick-rat Posted January 14, 2013 Report Share Posted January 14, 2013 good luck with your truck Quote Link to comment
