Dog leg 5 speed question
Dirttrack510
I have an L series 5 speed dog leg that is stuck in 1st gear and a z22 dog leg 5 speed that is rebuilt, but won't bolt up to a L series. Can I swap the guts out of the Z series case into the L series transmission case, to get 1 useable transmission? I'd hate to go back to a 4 speed.
  • Replies 2
Swap the L series front case half onto the Z series box and you're good to go.
L series dogleg had wider gear ratios (same as the 510 sedan 4 speed but with over drive)...
1st.... 3.382
2nd... 2.013... 1st / 2nd shift... 40.5%
3rd... 1.312... 2nd / 3rd shift... 34.8%
4th... 1.000
5th... 0.854
Z series dogleg had closer gear ratios...
1st.... 3.170...
2nd... 1.921...  1st / 2nd shift... 39.4%
3rd.... 1.312... 2nd / 3rd shift... 32%
4th.... 1.000
5th.... 0.854
This places 1-2-3 closer together and with slightly less RPM drop between shifts. Not much but it's there.
