steering wheel is locking up when im making turns
raulravega
  • Replies 7
Steering gear wear is mostly in the center or straight ahead position and less at full lock. If you adjust the gear lash in the center where all the wear is it will too tight on the turn positions. Be sure to have both wheels up off the ground when making adjustments to the box.Turn the wheel quickly from lock to lock feeling for any tight spots. If there is, slacken off the adjustment slightly. Usually a box wears and becomes loose not tighter.
Inspect the idler arm. may need grease or is worn out.
Raise the front and turn lock to lock, looking for any steering part rubbing anything else. This could simply be a piece of tree branch jammed up in there.
