Eric Posted December 3, 2012 Report Share Posted December 3, 2012 any tips i must get before starting? i have lots of rust around my windscreen and every time it rains i have a puddle in my 610, dont want that cause thats making my floor rusty. so i will try removing the chrome trim form around the screen and see what ill find.. Quote Link to comment
Skib Posted December 3, 2012 Report Share Posted December 3, 2012 theres a special tool for removing the trim from the clips Quote Link to comment
DATS_IT Posted December 3, 2012 Report Share Posted December 3, 2012 Wish i knew about that tool skib! be gentle with the chrome although Dato moulding seem to be fairly tough compared to the old holdens here in AU. From 610 experience you will find it as corroded around the area of the clips( and nail head looking pin which locates it) and the top and bottom line of the windscreen line at the lowest point. this is generally what i have found. the front screen moulding on the bottom corners flashes under the drip rail moulding via the bottom most screw (coupes definetly 4door and goon i cant recall) you need to remove the screw or otherwise they wont come off, as for the screen if you have not removed one before get the pro's out.. not worth wrecking a good screen, as for rebuilding the screen surround well i managed to do it but it is tricky and time consuming but well worth it. ohhh and if you can find thoose moulding clips the same please let me know as we cant get them here in oz.... i have somthing similiar however it doesn't work as well as the right fastener. my 2 cents/dime worth. Quote Link to comment
Skib Posted December 3, 2012 Report Share Posted December 3, 2012 on my 710 I got it with no clips and someone had cut all the pins off. so my glass guy found me some clips from a ~65 mustang that fit pretty damn perfect and screwed em in lol 1 Quote Link to comment
Eric Posted December 3, 2012 Author Report Share Posted December 3, 2012 Took out the screen today, wasnt the first time i did this, so that wasnt what i was worried about. Chrome almost fell off, no need for any tool, just a philips head screwdriver for the lower trim. Looks like i need to take of the front fenders as well because the rust in the lower corners from the screen is heading down.. This is what i found underneath, started the first repair, lots more to go. http://www.flickr.com/photos/57835122@N05/sets/72157632164219620/ Quote Link to comment
MicroMachinery Posted December 4, 2012 Report Share Posted December 4, 2012 All the 610's do that, man. Both of my coupes need some attention. Quote Link to comment
Eric Posted December 4, 2012 Author Report Share Posted December 4, 2012 it is rusting on all the pins that hold the trim clips. so i need to find chrome trim mounting clips that dont rust :) Quote Link to comment
