GERMS Posted November 30, 2012 Report Share Posted November 30, 2012 Hello, what would be a low, mid and high price for a stock, used, l20b flywheel? Quote Link to comment
LenRobertson Posted November 30, 2012 Report Share Posted November 30, 2012 Pull n Save Spokane gets $13 for one. Of course that is with the customer removing it, which very likely involves pulling the transmission. I have a feeling CA wrecking lots will be higher on price than that, but it will be interesting if people post some area different prices. A flywheel already removed seems like it should be worth a little more. Shipping will cost you some money, since they usually weigh over 20 pounds. If you put a Wanted ad here on Ratsun and on your local craigslist and find one you can pickup in your area, that will probably be cheapest. Len Quote Link to comment
hobbes_the_cat Posted November 30, 2012 Report Share Posted November 30, 2012 The ones I have seen (and bought) were in the 40-75 range already pulled, ready to ship. The one I assume you are talking about is the 6 bolt 200mm one. The 225mm ones seem to be more common and cheaper. OR go to Pull n Save or Pick n Pull like Len said and save more money in exchange for your time to pull it. Quote Link to comment
GERMS Posted November 30, 2012 Author Report Share Posted November 30, 2012 Thanks guys Quote Link to comment
banzai510(hainz) Posted November 30, 2012 Report Share Posted November 30, 2012 If ytou lived close by Id give you 225mm 6 bolt Quote Link to comment
