sergio510 Posted November 22, 2012 Report Share Posted November 22, 2012 Looking for coilovers for a 72 datsun 510 not looking too spend too much but show me what you have Link to comment
ggzilla Posted November 22, 2012 Report Share Posted November 22, 2012 The lowest price are the coilovers you already have. Datsun 510 uses large-diameter coilover springs. You can make them height adjustable by installing aftermarket threaded collars, $25 industrial shaft collars, or buy rewelding the stock spring perches lower. You can fit a variety of spring rates by swapping from other vehicles. Features: * variety of spring rates available * inexpensive * height-adjustable * can adjust for increased negative camber Cons: * afford slightly less room than aftermarket 2.25 coils * don't look as Bling as expensive aftermarket parts 1 Link to comment
LenRobertson Posted November 22, 2012 Report Share Posted November 22, 2012 From the reading I've done, the cheap eBay ones are okay, if you really want coilovers: http://community.rat...rear-coilovers/ On my 510, I'm going to do what ggzilla suggests, mostly cause it is cheap and I am cheap: http://community.rat...1-280zx-struts/ Len Link to comment
sergio510 Posted November 24, 2012 Author Report Share Posted November 24, 2012 is there like a video on how to do this The lowest price are the coilovers you already have. Datsun 510 uses large-diameter coilover springs. You can make them height adjustable by installing aftermarket threaded collars, $25 industrial shaft collars, or buy rewelding the stock spring perches lower. You can fit a variety of spring rates by swapping from other vehicles. Features: * variety of spring rates available * inexpensive * height-adjustable * can adjust for increased negative camber Cons: * afford slightly less room than aftermarket 2.25 coils * don't look as Bling as expensive aftermarket parts is there liike any video or site with more instructions or is it only what you mentioned Link to comment
datzenmike Posted November 24, 2012 Report Share Posted November 24, 2012 http://community.ratsun.net/topic/24412-my-76-710-goon/page__st__60 Link to comment
ggzilla Posted November 24, 2012 Report Share Posted November 24, 2012 Which part do you want to know about? Search youtube to get videos. There are lots of generic videos about this. Regarding coil Spring swaps -- not sure about Datsun 510 which is larger diameter than most datsun. Here are some Datsun-specific overviews with photos. Not 510-specific but will give the general idea. * Strut shortening * Lowering the spring seat * Lowering (for front strut Datsun) * Negative Camber for increased cornering power Link to comment
ggzilla Posted November 24, 2012 Report Share Posted November 24, 2012 If you're short on time and have the money, Ground Control has small-diameter coilover kit for $200. One issue with this kit is they only have very firm springs with the kit. But maybe if you phone the order they can supply other springs for it. They have a large selection of springs. Link to comment
ajen68510 Posted November 24, 2012 Report Share Posted November 24, 2012 Can always Powder coat the stock ones after modifying with collers. Can give the Uber Bling factor. Link to comment
datzenmike Posted November 24, 2012 Report Share Posted November 24, 2012 One issue with this kit is they only have very firm springs with the kit. But maybe if you phone the order they can supply other springs for it. They have a large selection of springs. For rear springs, you can substitute Dodge Ram D-50 front coils. Uncut they are 500 pounds spring rate and provide an installed spring rate of 132 pounds (about 35 pounds above stock) You can trim them to lower the ride height and increase the rate further. Link to comment
ggzilla Posted November 25, 2012 Report Share Posted November 25, 2012 I think you mean equivalent rate compared to a more standard suspension, because compared to most coil spring cars the 510 has the springs far inboard of the LCA (providing less leverage). The spring rated doesn't actually change, which you know but maybe some newbies will be confused. Link to comment
