Electric fuel pump ???
I did a search and didn't find a good answer for my setup(s)... Right now it is an L20B with a 32/36 Weber but will be changing to my SU's which are the
38mm round top's...
My question is how much PSI do you need to run it without a Fuel Pressure Regulator or a fuel return line? I thought I remember seeing somewhere it saying to run a 3-5 lb adjustable... Is this true?
Thanks
  • Replies 2
Webers don't like over 3lbs. I think the SUs as well.
The fuel return line, though not totally necessary, is a good idea. This keeps fresh cool fuel circulating past the carb even when under hood temps soar. Any vapor bubbles are pushed back to the tank. It also constantly filters your gas.
I run my SU's at 4 lbs. But my motor is mildly built 2.2. Either way you dont need a fuel return line. Just get a cheap regulator from Napa or some other parts store. You should be able to get a pump and regulator for around 50 bucks.
